Carb interchange years ? 67 Mustang 6 cyl - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-14-2008, 04:17 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
I just picked up a 67 Mustang conv stored 25 yrs in a barn. The 81 yr old owner said the carb shaft was rusted stuck, so he took it off for repairs. It's long gone. He said it was in the trunk,.... but that carb is a flathead Ford V8 Stromberg 2bbl 97
What years/models of Fords would fit? It's a one barrel manifold.
thanks
Old 12-14-2008, 05:28 PM
Wiki Edits: 31
Autolite 1100, Holley 1940, are the only 2 I can think of that are bolt on.. think a 240/300 Carter YF fits on the newer cylinder head, but if your cylinder head intake log is rounded, it's not the newer manifold.. would have to be a D1 or newer cylinder head to fit the 300 carb..
Old 12-14-2008, 05:37 PM
F&J F&J is offline
I've been web searching; I guess I have a 200 motor.
It's manifold is rounded and bore size is around 1-7/16"
Studs are 2-11/16" center-to-center.
Any ideas on the 240/300 carb measurements? I found a new one online....for $150+ less than Napa rebuilt one.
Old 12-14-2008, 06:10 PM
thanks
was the manifold covered well ? bugs , mice love them for food storage
spray down the cylinders with some lube and turn over without the plugs and lube up the bearings good .
and them bad about twisting oil pump rod after sitting .
if alls well , then i'd look for a carb .
friend bought a barn setter and it was locked up tight , carb rusted shut may be bad to start with . lets hope not .
Old 12-14-2008, 07:41 PM
Wiki Edits: 31
I just checked and the 300 carb will not fit the early heads... if the casting is a C casting, it will not work..... do you have the carb base water heater baseplate? you need that in conjunction with the carb... and you need to make sure the carb you get has a spark control valve if your running the factory distributor.
Old 12-14-2008, 08:01 PM
F&J F&J is offline
Yes it has the water heated base..
67 Mustang Tremec Install exiled1 Transmission - Rearend 1 11-05-2008 09:28 PM
67' mustang with 71 cougar 302, temp maxing out after a 10 minute cruise GimpCow Engine 21 10-30-2008 10:45 AM
Fitting 18" American Racing Torq-Thrust IIs on a stock 67 Mustang? ClassicNation General Rodding Tech 0 01-04-2008 08:12 PM
67 Mustang C4 BT74 Transmission - Rearend 10 05-06-2007 01:09 PM
Gas tank... difference between two years mustang shagginwagonvic Body - Exterior 1 01-18-2004 08:01 PM
