Carb issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2013, 03:31 AM
Nemeth's Avatar
My 327 Cruiser
Carb issues
Hey guys I got a 670 Avenger vac secondaries that i cannot get the secondary hesitation out. 383 sbc 180 cc heads,236/242 @ .050 duration 2500 stall 700r4, 373 gears. Maybe a 750 mechanical ???
Old 04-07-2013, 08:58 AM
vinniekq2's Avatar
you can fix the 67o. I use 750 or bigger on any sbc,but you have the 670.
Is the hesitation only when you sneak up on the secondaries or any time you floor it?
Old 04-07-2013, 11:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Often, secondary hesitation is caused by a too-quick opening rate. When that happens (too quick sec. opening) there's a lean "hole" in the air/fuel delivery. The way to counter this is to either slow the secondary opening rate (usually works best), or try to extend the accelerator pump shot to cover the lean hole.
There are several ways to tailor the secondary opening rate of a vacuum secondary Holley, but the first thing I recommend is to use the next stiffer secondary diaphragm spring and note the results.
Old 04-08-2013, 06:08 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Also check to be sure the secondary housing has the check ball in place, and that the check ball isn't sticking.
Click on image for more info:
Carb Issues NovaJoe1973 Engine 13 12-27-2011 08:12 AM
Carb issues mgregory96 Engine 4 10-11-2011 07:19 AM
Carb issues... petes67bird Engine 7 09-30-2011 10:58 PM
carb issues mjascur Engine 7 06-06-2010 05:52 PM
carb issues I think mjascur Engine 0 06-05-2010 09:08 PM
