Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb issues w/BB Chevy w/BDS blower
Old 12-29-2012, 05:06 PM
NOlowrider's Avatar
NOlowrider NOlowrider is offline
US Navy-Retired
Are you able to get the idle down by adjusting the curb idle screw? I always back the idle screw completely out on the rear carb and adjust the curb idle by the front carb, assuming you have a 1-1 linkage. Are you able to check the float level while it is running? Also check your fuel pressure. I run 5.5 psi
The Following User Says Thank You to NOlowrider For This Useful Post:
MuscleCarpenter (12-29-2012)
