Originally Posted by MuscleCarpenter
Thanks for getting back to me. I know rec-90 is low octane. The car typically runs fine on 93 alone, I add the race fuel to fatten it up and to be safe to prevent detonation (and smells better too). It's a low comp. motor (8.5-1), very street-able, doesn't make a lot of boost (between 8-10 lbs. at WOT. Never runs hot, only 185 degrees in stop-n-go traffic. Bad, stale gas makes a car run crappy, and I would agree with what you say normally, but the car is running great other than the fast idle. If its too lean would that make it idle fast?
yup did you create a extra air leak. Blew a vacuum hose off or blew the carb gasket or... power valve diaphram. A air leak will make it idle faster for sure.
I'd be getting it corrected before running that blower motor again under boost.
Cannot endorse using low octane fuel.
