Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb Lifter Plates?
Old 05-01-2004, 04:55 PM
1BAD80's Avatar
1BAD80 1BAD80 is offline
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
I would use the new type that is a 4 hole with the bottom half machined away and flowed.
I Believe they come in 1" or 2 " as in everything else always check for flatness of mounting surface. This is where most baseplate's break.
I'll find the name of it if interested.
Vacuum carbs liike the better siginal it gets from a 4 hole.
Use the 2" if you have the room.
Luv the smell of NITRO in the morning.
