carb.linkage - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-13-2006, 07:55 PM
carb.linkage
can a quad. be converted to manually secondarily? instead of vacuum.
Old 12-13-2006, 08:01 PM
poncho62's Avatar
Wiki Edits: 5
A` Quadrajet is a manual secondary.............Its the air horn on the top that is vacuum operated. I suppose you could have a manual linkage for it, but proabably wouldnt like the way it acted.
Old 12-14-2006, 09:26 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
I'm assuming by "quad" you mean any 4V carb, not just a Quadrajet. In general it's not easy to convert the linkage on any of them. Unless this is a strip only car you don't want manual secondaries anyway. If the secondaries open before the engine is ready/able to handle the extra fuel, it will just bog the engine. Vacuum secondaries prevent this by slowing the opening of the secondaries. They will open as fast as the engine can handle the extra fuel/air mix. Vacuum secondaries will provide as much power as fast as manual if the carb is tuned to the engine correctly. If the tune is off a bit, the vacuum carb will be quicker.
Old 12-14-2006, 09:59 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Not vacuum operated but air flow sensitive.
Old 12-14-2006, 10:49 AM
poncho62's Avatar
Wiki Edits: 5
Right...wasn't thinking...I do that a lot these days.
