carb lt1 using original optispark?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2008, 11:49 AM
i am currently converting my lt1 to carb setup. is there anyway (for the sake of saving a little money) to use the optispark on my application or am i better off with a good HEI dist, coil.... any info is appreciated. thanks
Old 06-04-2008, 12:29 PM
Wiki Edits: 31
the optispark is computer controlled so no, you will need a 4 pin HEI
Old 06-05-2008, 12:51 PM
thanks i appreciate it
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
600 v. 750 carb on my 350. Help me out! Porschev Engine 11 11-22-2007 02:58 PM
M4ME carb stumbles sometimes dies when letting off throttle in gear fast68 Engine 4 08-29-2007 05:57 AM
found an original holley carb, decode it ? fast68 Engine 4 01-10-2006 11:09 AM
desperately seek opinions for carb choice txsfld Engine 53 11-22-2002 04:08 PM
