carb overloads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-03-2009, 08:44 AM
carb overloads
my 383 runs pretty good butt has a problem with the 750 dubble pumper over loading. any help . the carb loads up what can i do?
Old 01-03-2009, 09:37 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
The carb is sized fine, rule that out.
If the problem is at idle...
1 Trash in the needle/seat front and/or rear?
2 Fuel pressure too high?
3 Blown power valve?
4 Previous 'mods' to the idle circuit? (if carb isn't new)
5 Gross mis-adjustment of idle mix screws?
"Dollars are like votes, except that they actually count."
Old 01-03-2009, 09:46 AM
kleen56's Avatar
Not sure what you mean by loading up? I'm guessing it's flooding and getting too much fuel. I would open the sight plugs on the fuel bowls and check your float level, sounds like they are too high. You have to have the car running to check the float level. It gets messy so have some rags ready. Adjust them to the point that gas barely trickles out of the hole. One or the other fuel bowl may be set too high set.
Demon or Holley Carb for 306 Ford? Dino Boreanaz Engine 10 12-09-2006 06:04 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
