carb percolation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2005, 09:06 AM
New Member
carb percolation?
I have a 55 chevy and am running a 400sbc, edelbrock 1405 carb(with heat insulator),edelbrock fuel pump, braided hose, etc.I drive about 2 miles and it starves and stalls. I open the hood wait about 5 minutes and it will start again. Any suggestions?
Old 04-11-2005, 12:52 PM
Fuel pressure?
Is your fuel line too close to headers/exhaust?
Did you check your fuel filter?
Did you check your carb fuel filter?
Old 04-11-2005, 03:44 PM
Rhansen's Avatar
Footbraker
My 1406 carb used to have heat sink problems, tried a heat diffuser with no luck. I ended up making a 4 hole spacer from some pine wood using one of the diffuser plates as a template - problem solved.
Definitely check the fuel line to see if it's picking up heat along the way since you already have an insulator.
Old 04-11-2005, 04:16 PM
club327's Avatar
Should'nt be through excessive heat after only 2 minutes driving. When it happens, see if any fuel pumps into the carb venturis when opening the throttle. You could have a sticking needle and seat. Also make sure your engine's crankcase is vented to the atmosphere, and not just fitted with a PCV on its own as this would create full crankcase vacuum, which would act on the fuel pump's diaphragm and stop it from pumping. Like the others, check your filters for garbage.
Old 04-11-2005, 06:01 PM
New Member
Thanks Darom.R Hansen and Club327
Thanks
Darom,Rhansen,club327-I'll give them a try and let you know what happens.
I just got back into hot rodding after a thirrty year layoff and never encountered this.
Thanks again,
Bill cherry
New York
Old 04-12-2005, 02:47 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
vacuum
You could be pulling a vacuum on your gas tank. Try running with the gas cap off. If it works. Buy a keyed gas cap. The keyhole acts as a vent.
If you are perculating the carb should be hot to the touch. You should also see gas dribbling down the carb from the shooters.
Old 04-12-2005, 08:23 PM
New Member
Thanks
Bracketeer ,
thanks for the sdvice . I'll let you know what happens.
Bill C
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 03:23 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 04:36 PM
Broken ear (flange) on Holley carb ford302 Engine 12 01-04-2005 04:09 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 02:10 PM
priming a new edelbrock carb crshrmn3 Engine 8 10-29-2002 06:04 PM
