Carb ? please help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2012, 10:30 AM
Carb ? please help!
I have a 1406 carb edelbrock and I'm get arich exhuast smell, checked plugs there fine. I also read that the primary butterflies opened to far it will cause this. My ? is how do I ajust them or what cause's them to open to far. I aslso have electric chocke hooked up do I adjust it there? Like to thank you ahead of time!
Old 10-02-2012, 11:21 AM
RWENUTS's Avatar
It's about timing!
SEt your timing at 12* and hook your vacuum pot up to manifold vacuum. Slow your idle back down and you'll have the carb back in sync. Rich smell is caused by uncovering the idle transfer slot too much and getting into the power circuit too soon.
Old 10-02-2012, 03:34 PM
Carb Help
Thanks I'll try that first!
Old 10-02-2012, 04:49 PM
Irelands child's Avatar
Get your instruction book out that came with the carb - or if it has disappeared, Edelbrock has it posted on line: http://www.edelbrock.com/automotive_...406_manual.pdf
It can be confusing so you do need to spend some time understanding what does what.
Irelands child
holley carb backfires threw carb talleyho Engine 63 01-04-2016 10:43 AM
350 carb question demon carb to much? Studedean Engine 5 04-22-2012 12:44 PM
Will adding a 1 inch carb spacer affect carb tune? eric32 Engine 29 02-09-2010 12:13 AM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
Any problems spraying carb cleaner in my carb while its on the motor? batman09 Engine 11 11-29-2005 07:49 AM
