Carb problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2008, 01:05 PM
Carb problem
We have an aluminum big block modified engine in our truck when we race on flat ground she has no problem but at the races on the beach she had problems after a jump, we leaned out the jets and lowered the floats but still had problems she was back firing? Do you think this is carb related or timing? The first time it happend she back fired and was spitting out fire and the engine quit and wouldn't restart un til the next morning, we took out a spark plug and then she started up again??? if this makes any sense to anyone let me know....thanks Mrs. Greenhead
Old 09-29-2008, 01:29 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Sounds like fuel slosh flooding it out...except for the spitting fire part, but that may be due to cammed up??
Can you search around on the monster truck sites to see how they handle fuel slosh? Once in a rare while, you will see a monster go all flooded after a nasty jump...but I don't know if those are carbs or injected??
Old 09-29-2008, 01:55 PM
Jmark's Avatar
It is most likely fuel caused. Making jumps or for us regular off roaders, a good jolt or a tough hill can cause flooding and stalling. That is why most have now switched to some sort of injection.
Old 09-30-2008, 06:18 AM
Carb Problem
Thanks guys, I am going to check into the monster trucks I do think they are injected though..my hubby doesn't want to go the blower route because he sometimes switches the engines into modified dirt car. I am going to try to get the video up so you guys can see when she over loads it only after a jump in he race. We also have a strange suspension system all four wheels are independant swing arms...with hummer gear boxes that part(the suspension) works great but could that be causing part of the carb problem? My husband has been building this truck for 3 years now and he took apart the old truck so he would finally get this one done so I want to get him some help he is really bummed...but thanks for your input.
Holley (ProForm) Carb Problem leejoy Engine 30 04-01-2011 11:36 AM
Odd Carb Problem... TurboS10 Engine 11 06-22-2007 05:15 PM
1972 Cutlass Carb problem goodnight144 Engine 2 12-02-2006 05:54 PM
carb problem... oakland_raiders Engine 4 01-07-2003 07:20 PM
carb problem 65galaxie500 Engine 2 10-22-2002 03:33 PM
