carb problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2004, 08:59 PM
interceptor429's Avatar
New Member
carb problem
hey guys could someone tell me how to set the idle on a 1975 chevy nova 250 6cyl ,i'v looked and looked cant seem to find an adjusting screw anywhere ,it idles to low in gear and dies when you come to a stop in gear , please help ,thanks interceptor429
Old 03-27-2004, 09:08 PM
poncho62's Avatar
Wiki Edits: 5
Chances are that there isn't an idle mixture screw (preset at factory), but there should be an idle speed screw. Should be near the bottom of the linkage, by the throttle shaft.
Old 03-27-2004, 09:48 PM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Also, make sure the choke is not stuck shut, and is working right.
Old 03-28-2004, 06:21 AM
Tazz
Nova wants to die
Did you find the adjustment screw on the linkage?
Tazz
Rat Rods Rule!
