carb problem... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2003, 07:25 PM
New Member
Post carb problem...
alright i got my carb back together..... i put it on the car and with a couple of pumps it fires right up.... its runnin real smooth... runnin good.... then as the choke comes off the engine starts to shake and doesnt stay on unless i hold down the gas.... i tried adjusting the mixture and it aint working????? it backfires sometimes.... i put it in gear and drove the car around the block and it was runnin LIKE ****.... i think i put it back together wrong!!! the NIEHOFF carb kits SUCK there instructions are really bad....
Old 01-04-2003, 07:45 PM
Post
When you rebuilt the carb, did you pay particular attention to getting the float adjustment to specs. It sounds like its running too lean.
One thing you can do to check this, is when the choke starts opening and the engine starts running rough, slowly start covering the top of the carb with something (not your hand) and if the engine starts running good again your running too lean.
Old 01-04-2003, 09:01 PM
4 Jaw Chuck's Avatar
Post
What kind of carb?
— Han Solo
Old 01-04-2003, 09:11 PM
New Member
Post
its off of a 1979 pontiac firebird.....
its a Rochester DualJet 210 2bbl
Old 01-07-2003, 07:20 PM
New Member
Post
YES!!!!!!!! got the carb rebuilt right...... i took the carb off and took it apart again and found that a couple parts were not exactly how they were supposed to be and i put everything right... YES!! before i wouldnt even be able to press the gas pedal in a lil bit before it would sputter now i got on the freeway and gunned it it just needs to be adjusted a little because at a stoplight it will start to sputter a little... also the timing might be off a little.... what should i set the timing at??? it says 4 degrees at 600..... should i just set it as recommended?
