Carb problem-please help - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-02-2010, 10:19 AM
I just had my edelbrock 600cfm carb overhauled, now when I start the car I can't get the idle below 1000 rpm. And if I try to adjust the mixture screws I can turn them in all the way and it still runs, the mixture screw adjustments make no difference at all.
does anyone have any ideas? The engine is a stock 350.
Old 06-05-2010, 06:36 AM
carb problems
u need to drop the metering rods size down buy 2 sizes to richen up the fuel mixture it is runnin to lean.
Old 06-05-2010, 06:39 AM
hi idle
i forgot to tell ya to check for vaccume leaks do that before u replace any metering rods.. u can check by sprayin carb cleaner around the carb if it idles up then thats youer problem
Old 06-05-2010, 11:53 AM
Rhansen's Avatar
Footbraker
Sounds to me like your idle speed screw is too far in and it is not running on the idle circuit.
Old 06-06-2010, 01:22 AM
JeffB's Avatar
Manual or electric choke?
Old 06-06-2010, 06:20 AM
X2
Where do you get the 1000 RPM? A reliable gauge/meter?
You dont have to go up very far on RPM to have it start drawing off the main jets.
Old 06-06-2010, 08:48 AM
T-bucket23's Avatar
Wiki Edits: 26
Sounds like you need to bring it back to whoever overhauled it and make them fix it. If you can turn the mixture screwes in all the way with no effect either it is not on the idle circuit or there is fuel getting in somewhere else
Chet
Holley (ProForm) Carb Problem leejoy Engine 30 04-01-2011 11:36 AM
timming problem?? or carb problem???? helppp 85 k5 mud truck Engine 10 06-05-2009 04:59 PM
Odd Carb Problem... TurboS10 Engine 11 06-22-2007 05:15 PM
1972 Cutlass Carb problem goodnight144 Engine 2 12-02-2006 05:54 PM
carb problem 65galaxie500 Engine 2 10-22-2002 03:33 PM
