carb problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2004, 09:49 PM
carb problems
I know this is a lame post. I borrowed a friends car on the way home it started running like crap. I turned the idle screw all the way in and it would stay running fuel is pouring into the secondaries. All I know about the carb is it's a holley 4-barrel vacuum secondary. If I turn the float level screw in on the rear and disconnect the vacuum line can I drive around until I get parts.
thanks
Dave
Old 08-15-2004, 04:38 PM
Sounds like a vacuum leak ,check all your vacuum ports (trany too) and around the carb and intake
