Carb Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2007, 03:57 PM
Carb Question
Ok Guys I Got The Chevy 350 Running.....finally. All I Have On This Thing Is A Edelbrock Performer Intake, Flat Top Pistons, And Headers. Well I Found A Holley(list 6919, Model 4160) 600 Cfm, Electric Choke, Vacuum Secondary. It Has Size 62 Jets On The Primary Size And A Metering Plate On The Secondary Side. My Question Is Are Those Jets Going To Be Too Small Or Should I Replace Them. I Had The Engine Running For A Brief Minute And My Intake Got Really Hot. The Exhaust Gets Really Hot Too. I Can See Where Its Turning The New Exhaust Pipe Kind Of Purple. What Do You Think?
Old 01-19-2007, 04:07 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
Check your timing and water flow. I dont think it would be that lean.
Old 01-19-2007, 04:11 PM
poncho62's Avatar
Wiki Edits: 5
Those jets sound about right.....At idle, the jets dont come into play....maybe the idle screws need adjusting. Put a vacuum gauge on it and set the idle screws.
was it getting hot at idle, is all the coolant in the engine?
Old 01-19-2007, 06:08 PM
Carb Question
Yeah Purple Chrome ? Intake leak and or Timming issue Combo and Lean all 3 ? Sean
Carb question revisited Bob23T Engine 2 10-07-2005 04:32 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 04:51 PM
302 Carb question Thuggishruggish3000 Engine 5 01-07-2004 08:16 PM
Holley Carb Question 1965-Mustang Engine 1 10-26-2003 02:44 PM
Carb question 59vette Engine 8 10-12-2003 06:07 PM
