Carb Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2010, 01:02 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Carb Question
Three questions:
1. What is a Q-jet carb body made of?
2. What is a "traditional" Holley made of?
3. What is the throttle plates of either/both made of?
Thanks in advance for any and all responses. However it may go.
Old 03-14-2010, 05:04 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I always thought the main body's were cast of zinc, and the base plates aluminum on both the Holley and Q-jet.
I have seen stainless steel replacement throttle blades.
Old 03-14-2010, 05:36 AM
TroyBoy's Avatar
Psychomotors
I agree with 1ownerT. That is what I've always been told.
Old 03-14-2010, 11:19 AM
quadras are aluminum bases , aluminum throttle plates( some are anodized steel ), steel shafts that are chromated or epoxy coated and zamac #2 ( zinc aluminum alloy) tops and centers
holleys are basically the same style of construction , except the early ones which used a iron base . the polished holleys are a zamac with a high aluminum content and a special coating .
Old 03-14-2010, 11:28 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I know the 4010/4011 Holleys are said by Holley to be "aluminum".
If I understand your reference to Zamac or Zamac 2, that is zinc alloy w/4% Al added (3% Cu also added to Z-2), right?
Old 03-14-2010, 12:52 PM
all I know was it was called zamac , didn't know there where different versions of the alloy , all I know is that they made the alot of the Rg handguns out of it and it would come apart quite easily if it got heated and disolves easily if put in hydrochloric acid thats why certain states outlawed them . the 4011 carbs ( that was the open top right?? ) they had a disolving problem with certain fuels , I had one on a 350 chevelle I built for the ex wife and when I used cheap fuel ( that contained methanol or alot of MBTE ) , it ate the casting from the inside out in three years .
Old 03-14-2010, 01:04 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yeah, Holley discontinued them and they were picked up by Summit.
Never cared for the one I got in trade (600 CFM 4010)- it required a booster swap to change the shooter size.
The Zamac info I'm going by was from HERE as well as verified elsewhere, so I'm comfortable w/the description above.
Carb Spacer Question Regal Beagle Engine 6 07-18-2008 06:04 AM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
Carb question revisited Bob23T Engine 2 10-07-2005 04:32 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 04:51 PM
Holley Carb Question 1965-Mustang Engine 1 10-26-2003 02:44 PM
