Carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2010, 12:24 AM
Carb question
This may sounds stupid to some but oh well I was wondering what is the difference in the sizes of your primary metering rods in an elderbrock carb I guess really my question is if I gett bigger metering rods what will the change be I have 7142's in it right now it's a stock 750 nothing has been chaged in it yet I just rebuilt it and put all new gaskets and stuff in it thanks for any info
Old 06-10-2010, 02:41 AM
DoubleVision's Avatar
Metering rod carbs such as Quadrajets and Carter (edelbrocks) are just that. They use metering rods controlled by the vacuum signal on the primary side. The metering rod tapers down smaller as it goes so as it`s lifted out of the jets the mixture gets richer. Smaller metering rods are richer, larger ones are leaner.
Carb Spacer Question Regal Beagle Engine 6 07-18-2008 07:04 AM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 09:02 AM
Carb question revisited Bob23T Engine 2 10-07-2005 05:32 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 05:51 PM
Holley Carb Question 1965-Mustang Engine 1 10-26-2003 03:44 PM
