-   -   Carb Question (http://www.hotrodders.com/forum/carb-question-210234.html)
UPandComing 12-12-2011 11:42 PM
Carb Question
OK on blower ENGINES or even engines with tunnel rams you see the carbs mounted sideways, why? and another thing why on holley type carbs do i see guys attaching rubber hoses from the front bowl vent tube to the rear?
That out of the way now on a 620HP SBC 388CI stroker could i mount the carbs sideways and would it be beneficial?
SSedan64 12-13-2011 07:46 AM
There's not enough room for the Fuel bowls to mount normally.
To prevent Fuel from splashing out of the vents on hard launch, steep angles etc..
