Carb. question for '67 Mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2006, 01:55 AM
Ok, I am new at working on cars.....the '67 mustang that I have is an in-line 6 2oo, with a 1 barrel carb. the carb,. is sticking ...or something. It will die on me while driving...when I pull over and open and close the carb, then it will start right back up. Can anyone tell me how to fix the problem....besides buying a new carb....lol...i am a single mom with 3 kids and just want to learn how to fix things. Thanks guys!!
Steph
Old 05-26-2006, 04:57 AM
there are several good carb diagnose and repair links in the Knowledge Base link above under engines/articles/carbs....one that I like is the "recarbco" link....shortcut is use the search window for recarbco
Old 05-26-2006, 08:10 AM
Biggarmike's Avatar
Chief Procrastinator
Cheap possibility: Fuel filter or screen, IIRC, that carb has a screw in filter that can be replaced in about 2 minutes. It could be a $5. fix. (starving for fuel, the quick pump of the carb gives it a little squirt from the accelerator pump. the time it takes you to try it again lets the carb bowl refill) That would be a likely trouble if your car has a cruddy old tank, rubber sections in the fuel line, or the original fuel pump. Even more likely if the gas in your area has MBTE or ethanol in it.
Old 05-26-2006, 11:27 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
If you are a little mechanically inclined, try this:
Go to NAPA and get a fuel filter and a carb rebuild kit, for around $20 or so.
The fuel filter is probably clogged if it hasn't been replaced in awhile. The carb may not need a rebuild, but it sure wouldn't hurt, and its hard to tell whether that's the problem if you are not used to messing with carburetors. You can rebuild the carb on a bench or table in a couple hours, its just disassembly and assembly (lay out the parts in order as you take it apart, then put it back together in reverse...). I did my first carb at 16 with no help, while my little sister annoyed me -- if I can do it you can do it.
I think Biggarmike may be onto the problem, I had that with my 69 Maverick (same engine and carb as yours!)
Good luck and let us know how you do.
Question for BG Tech or other carb tuner airman_turtle Engine 18 06-28-2005 03:25 PM
Carb spacer question Gametech Engine 5 05-21-2005 11:04 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 05:51 PM
600cfm Carb question calimstng66 Engine 12 04-19-2004 09:34 PM
Holley Carb Question 1965-Mustang Engine 1 10-26-2003 03:44 PM
