Carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2005, 06:16 PM
chianesi's Avatar
Never Give Up
Carb question
I have a 78 silver ann. vette 350 w/ a Q-jet m#17059222. The engine will start and idle as long as I keep the choke almost completely closed. The moment I let go of the choke the engine immediatley stalls. I have to hold the choke closed in order for it to start even if the engine is at running temp. The carb is brand new and worked just fine, engine ran...9 mo. ago when it was last started.
Anybody got any ideas...
Old 08-17-2005, 06:19 PM
67 Deuce 4 Me's Avatar
Bowtie or Die!
Sounds to me like its Starving for fuel. Or has a large vacuum leak.
Old 08-17-2005, 06:42 PM
tornado-tech's Avatar
Definitely I agree. Try spraying carb cleaner around the carb and intake to see if the rpm picks up.
Old 08-17-2005, 06:51 PM
Jmark's Avatar
If it sat for 9 months, the gas probably evaporated and left some reisidue in the bowl which may have clogged the jets. Metering rod piston may be stuck too. May be time to remove the carb and pull the lid and take a look if you don't find any large vacuum leaks first.
Old 08-17-2005, 11:57 PM
docvette's Avatar
Wiki Edits: 12
Carb
Doc here,
Or varnished stuck floats...
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 08-18-2005, 09:28 AM
chianesi's Avatar
Never Give Up
Thanks guys, I'll get back...
Carb spacer question Gametech Engine 5 05-21-2005 11:04 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 05:51 PM
Carb question 59vette Engine 8 10-12-2003 07:07 PM
Q Jet carb question motoxracer Engine 2 07-21-2003 12:28 AM
4.3 question FI to carb highlander007 Engine 3 12-30-2002 05:16 PM
