carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2005, 01:30 AM
New Member
carb question
i got a carb question for you guys. i was wondering if you can help me pick out a carb for my motor. i have a 383 with dart pro1 200cc heads, comp xe268h cam, rpm air gap manifold,and 10to1 compression. im looking to get a carb that is going to be easy to work with, i do not know very much about carbs. someone i talked to before said to get a 750 is that a good size to get? this motor is going into a 70 Chevy truck and is just going to be driven on the weekend. any info would help.. thanks
Old 08-29-2005, 12:32 PM
BOBCRMAN@aol.com's Avatar
If you don't like to fool around with carbs, the vac secondary 750 is your best bet. I prefer Holley, but get what you want. The vac secondary will keep you out of trouble, yet you will love the power and decent gas milage.
Old 08-29-2005, 02:39 PM
347mustang's Avatar
yep..a 750 holley ..maybe try the advenger series..they are dang near set from the factoryn to most people liking....i have a 750 holley vac sec carb and i would not trade it for anything...i put a heavy spring in the sec on the street and a 30 sec spring change at the track and i get all the fuel it needs..every one is different.some liie the demons..some like the holley dp and hp....but since you seem to be a little carb challenged( not know much about tuning carb) i would highly recomend the holley avenger carb..
Old 08-29-2005, 06:12 PM
New Member
the avenger might be right for me. im just worried about tuning it. does a 750 sound about right for my truck?
Old 08-29-2005, 06:21 PM
jpelli's Avatar
I'm running a 383 in my street rod with a 770 Holley street advenger carb vacuum secondary, the only tunning I had to do was with the electric choke. Can't go wrong with this carb. They don't make a 750 it's 670 , 770, and 870 cfm.
Old 08-29-2005, 07:50 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Yep definitely..... Avengers are good.
In the past I have had good luck with the spread bore "Quadrajet" that Edelbrock is reproducing... Good mileage with the small primaries and 800 cfm on all 4..
Old 08-31-2005, 09:00 AM
New Member
thanks fro your help.im going to look into the avenger.
Carb spacer question Gametech Engine 5 05-21-2005 10:04 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 04:51 PM
Carb question 59vette Engine 8 10-12-2003 06:07 PM
Q Jet carb question motoxracer Engine 2 07-20-2003 11:28 PM
4.3 question FI to carb highlander007 Engine 3 12-30-2002 04:16 PM
