Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb question about secondary barrel control
Old 10-11-2012, 04:03 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
FYI: The manifold vacuum has nothing to do with the opening of the secondary air valve or vacuum secondary in a Holley carbs. What causes the secondary to open is the air traveling threw the venturi in a carb. Manifold vacuum drops down to almost zero when the throttle is at WOT. Secondary open on demand when the motor needs it.
The Following User Says Thank You to lg1969 For This Useful Post:
Silver Surfer (10-11-2012)
