Carb Question...electric choke instructions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2011, 01:49 PM
Mac88's Avatar
"Drive It Until It Breaks"
Carb Question
I have a 670 Holley Carb on my 88 Mustang. These carbs came from the factory with the electric choke. When I bought the car, the complete choke assembly was missing. So I ordered a replacement choke from summit. I have it now, but the instructions, and every set of instructions I've been able to find are more along the lines of converting a carb with a manual choke to a electric choke. Does anyone know where I can find some simplified instructions on just how to install or replace the electric choke? I'm sure I will not need some of the parts that came with the choke, but I want to make sure its installed and adjusted correctly. One more question that may be silly, but should I have to bend the connecting rod, or should it already be pre-bent to fit the carb. Only asking because it looks slightly different than the rod that was left hanging on my carb.
Old 12-03-2011, 02:25 PM
poncho62's Avatar
Wiki Edits: 5
Going to move this to General Rodding Tech, as its a bit more than just an electrical problem
Old 12-04-2011, 05:51 AM
Here is some good general info on choke operation/setup http://www.chevelles.com/techref/Adj...tic_Chokes.htm
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
Carb question?? Bob23T Engine 11 10-05-2005 08:32 PM
Carb question chianesi Engine 5 08-18-2005 08:28 AM
carb question strracer7 Engine 9 03-15-2004 08:22 PM
carb question mightycaminotw Engine 2 11-29-2002 08:05 PM
