carb questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2004, 12:27 AM
mitmaks's Avatar
Last journal entry: Grille
carb questions
ive just won this carb, would it be good carb for street/strip, ive got stock '68 charger r/t with 440, but ive got intake for it that ill install when i install carb and im getting headers
what are your thought on this carb guys?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
Old 04-29-2004, 01:34 AM
DoubleVision's Avatar
I love my road demon Jr. Demons are great carbs, but there not like most other carbs, there very precise and must be tuned to the application, if the instruction manual don`t come with the carb, it would be a good idea to call BG and request one, it`ll really help you get the bugs worked out of it and right on the first go round, in other words, it`s not a bolt it on turn a few screws carb, the settings have to be on the money for it to perform correctly.
Old 04-29-2004, 05:02 AM
I dont understand the love for the demons, they are just another holley clone. I know they are of better quality than holley, but they are still just another clone.
Old 04-29-2004, 06:05 AM
Technical Support Barry Grant
mitmaks:
That carburetor is going to be a little big on a stock 440. Which will make the idle a little rich, and throttle response won't be as good as a smaller carburetor would be with a slightly smaller carburetor. You could have that carburetor converted over to annular style boosters which would help with your situation.
Old 04-29-2004, 06:14 AM
stepside454's Avatar
wow, now thats customer service
Old 04-29-2004, 05:04 PM
mitmaks's Avatar
ill be adding headers, aftermarket Weiand intake, MSD ignition, would it still be big? ive been told that factory '68 440 had ~750-850 cfm thermoquad carbs on them
Old 04-29-2004, 06:01 PM
Demon carburetors are much less restrictive than other brands of carburetors. That being said our 850 Speed Demon is going to be a bit large for this application even with the changes you are going to make. Converting the carburetor to annular style booster should get it to work properly on your combination.
Old 04-29-2004, 06:12 PM
mitmaks's Avatar
how would i convert it? is that expensive, easy to do?
Old 04-29-2004, 06:26 PM
Id use a 670 Holley vac. sec. on a stock 440 personally if you plan to keep it within 5000 RPMs. John
Thermoquads are a spread bore design, they are more universal & foregiving due to there design, simialer to a Qjet.
Old 04-29-2004, 07:10 PM
firestone's Avatar
http://teamrfc.gospelcom.net
As far as the size goes, I was building a 468 and working with comp cams. That motor was going to be rapped to 6200 rpm, and they recommended an 830 cfm carb, so a 850 might be a tad big on a 440, you could make it work though. As far as barry grant carbs go, I have heard that an average holley dp carb will flow around 10% less than what they advertise. An average demon carb will flow around 10% more than what they advertise, that is why they are so nice. Where a stock 850 holley might only flow around 770-800, a demon 850 will flow around 910-930.
Adam
Old 04-29-2004, 08:23 PM
mitmaks's Avatar
thats nice to hear, i guess i got good deal afterall, i wont be keeping 440 all stock, as $$ comes in ill beef it all up, new heads etc.
Old 04-30-2004, 06:04 AM
850 Speed Demon on 440
You can send the carburetor to our factory, and we can convert it to annular style boosters for $65.00. As it sits it's going to be too large for the combination.
