matter of prefrence. but I prefer Holley myself.
cam
I would stick in a Lunati VooDoo 60103 cam & lifters, use the reccomended springs, port match your heads for your intake gaskets, put a 3310 750 single pump Holley on, run your timing on the low side but not real low, leave your Holley just like it is out of the box, put a fuel pressure regulator at the carb and run about 6lbs, slide in a 2800-3200 stahl and go out and have some fun! JM2C
Last edited by Camaro_Nut2001; 05-15-2010 at 09:50 AM. Reason: Forgot to mention springs. |
i drive my truck real damn hard, built for straight out mud bogging, has 400 pounds of tires on the rearend to swing alone. and i can roast em on dry pavement.
i dont give a **** what anybody says, edelbrock is a damn good carb,im not saying holleys dont work good, im just saying theyre a nuisance. |
Edelbrocks run pretty good right out of the box, but if it needs any tuning, it will be much faster/ easier to tune in a Holley.. generally, Holley's do need tuning, but hardly a nusience
Edelbrocks can give better road manners, and even some gain in MPG, but at a cost of performance |
X2
Hot Rodding
Well here is my experience. I have a 350 chevy making close to 400 horses and I first used the Edelbrock 600 performer carburetor and it was fine for regular use and driving. It was lean for my engine so I got a tuning kit and kept messing around with it to richen it up and got it close.
I then went and read up on Holley carb's and learned how they work and how to tune them for different setups. I got a SA design book on Holley carburetors and it has many good tips on tuning. I read and did a lot of research on Holley's and how to tune them etc. I finally went and got a holley carb which was a holley 670 aluminum street avenger. Too much history to list here but anyways it had quality control issues out of the box. Sent it back and ended up with a brand new Holley 600 1850 s 4160 style carburetor. It was lean to start off with so I jetted it up and did the fine tuning with it and it gives way better throttle response then the edelbrock and out performs it all around all together. Now the fuel mileage was slightly better with the edelbrock but not by much. I recently went on a hundred plus mile round trip and cruising down the interstate at 65 70 mph I got about 17 mpg and could of got 18 mpg if I stayed at 55 mph. Holley's are nicer and easier to fine tune in my opinion and the edelbrock's are fairly easy to tune as well with a calibration kit. If you got a stock type motor or just a mild cam with 220@ 50 or less the Edelbrock will work well. If you get anything bigger cam wise then you should consider a Holley carb as they will tune better with bigger cams so you can really fine tune better. There is no perfect carburetor. Holley has pros and cons just like Edelbrock does. I would recommend the holley 1850s 4160 for 245 bucks from summit if you can swing it. I myself and my Dad and Brother all are using one and love them. My Dad is using one on a ford 302 and my brother a chevy 305. Hope that might help you out some. Don't make a quick decision read up on Holley and Edelbrock and then make a choice. Just go with 600 cfm carb and that will give you better bottom end then a much bigger carb. Take care Eric |
let me get this straight. if a fella hooks up an A/F to his exhaust w/gauge on dash and he's pulling down ideal A/F, does it matter if it comming via eddy,holley or a little monkey sitting on the fender squirting the fuel in. A/F ratio is A/F ratio,is it not?
yes and no.. the fuel metering in a Holley can give a better throttle response, and the fuel metering from a Edelbrock can give better mpg.. there is no perfect A/F ratio. it's constantly changing, and because the way the carbs work diffrent, they will change in diffrent ways.. Both Holley and Carter AFB/ AVS ( now Edelbrock ) were used in the OEM. so both have good points and bad points
Iv got some holley's and some eldebrock's aswell too, they both are good carbs, to me eldebrocks are easier to mess with, but out of the box lets say a eldebrock vs holley, for power the holley will be the best, for the street the eldebrock is way better than factory!!!
OK, Ill be the "bad guy". It's a dirty job but somebody's gotta' do it..........
QUADRA-JET There, I said it and I'm glad I tell you! I'm glad!!!! (Insert maniacal laughter). If you have never tuned a carb before though I suggest starting with a Holley or Edelbrock. Tuning Q'Jets is not for beginners unless they have a VERY good friend that will show them the ropes and two very valuable books. Rochester Carburetors by Doug Roe and Rochester QuadraJet Carburetors by Cliff Ruggles. They are a very sophisticated piece of equipment and can be a royal PITA at first but once you get one dialed in it's worth every second you spent getting it there. Once you learn your way around one though you'll be hooked. |
I AGREE 100% QUADRAJUNKS may have a bad rep. but if you built it RIGHT. and make it not leak, they are THE best all around STREET/STRIP carb. little tiny primarys lets you va-jj foot it around when cruzin, and a monster supply of fuel when you W.O.T. QUESTION...is there a square bore quadrajunk? never seen one |
| Holley or Edelbrock Carb? | klutchmaster427 | Engine | 19 | 09-14-2009 04:54 PM |
| Need to downsize from my 750vac sec Holley. Want your choice of carb and why! | club327 | Engine | 20 | 02-05-2006 10:27 PM |
| edelbrock vs. holley carb | Super Chevy | Engine | 43 | 01-21-2006 09:55 PM |
| Holley carb interchangeability questions | commando57 | Engine | 4 | 02-21-2005 06:52 PM |
| Edelbrock Carb | Chadman | Engine | 17 | 12-09-2003 01:10 PM |
