carb questions. holley or edelbrock? why? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2010, 09:51 PM
i got a 350 motor out of a 72 camaro runs good but has a 2 barrel carb. i also have an edelbock 2101 intake laying in the garage. what else do i need? besides carb? spacers?
Old 05-14-2010, 08:45 AM
DoubleVision's Avatar
All you need is a set of intake gaskets and some RVT sealant. Get the cheapy Mr. Gasket intake gaskets that hang on the shelf of almost any parts store. Use the RVT blue glue to be the end seals on the china walls. When you go to remove the old intake and clean the heads for the new gaskets and intake, make sure you place a large towel in the lifter valley, also make sure you stuff paper towels in the intake ports. If you use a holley or Edelbrock carb you`ll need the plate that sandwiches between the gaskets to prevent a vacuum leak. Do not use any spacers or adapters. If it were I, I would use a Quadrajet as it`s small primary`s help low end torque and economy. If you bolt on a holley or edelbrock there won`t be any power difference from the Quadrajet.
Old 05-14-2010, 08:54 AM
thanks
i wanted a qjet. my friends are dummys and said qjets had no power...should i change cam...someone said i would nt feel any difference with just changing carb intake and headers
Old 05-14-2010, 09:03 AM
How fast is fast enough?
If its tuned right you'll feel a difference, will a cam help still, definitely.
Old 05-14-2010, 09:03 PM
your the man
thanx
Holley or Edelbrock Carb? klutchmaster427 Engine 19 09-14-2009 04:54 PM
Need to downsize from my 750vac sec Holley. Want your choice of carb and why! club327 Engine 20 02-05-2006 10:27 PM
edelbrock vs. holley carb Super Chevy Engine 43 01-21-2006 09:55 PM
Holley carb interchangeability questions commando57 Engine 4 02-21-2005 06:52 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 01:10 PM
