Carb Rebuild Gone Wrong?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2010, 04:03 PM
DeathRattle's Avatar
Some Punk Kid
Looking for a little guidance on this one, as i am pretty much run dry on ideas at the moment.
This all pertains to a Holley 670 Vacuum secondary
Tore it down and cleaned it and put all new gaskets on it cause it sat for a few years. The motor ran and everything before i tore it down last week and the accel pump worked like a charm.
After assembly I get nothing from the squirters shooting into each barrel?
The fuel bowl is filled and float is set spot on.
I took the fuel bowl off and plugged the accel pump hole with finger and gently try to depress lever..it holds just fine so i assume the diaphragm is still good right?
Put it all back on and still nothing from the squirters..what you guys think?
Thanks for reading and any replies on the issue.
Old 06-23-2010, 04:14 PM
ericnova72's Avatar
More for Less Racer
There are two check valves in the accelerator pump circuit.
One is a steel needle about .090" in diameter and 3/8" long, it gets dropped in the passage hole below the shooter with the point facing down.
The second is usually a rubber umbrella type seal(usually orange colored) in the bottom of the pump cavity on the fuel bowl. The tip on the umbrella seal is pushed through the center hole in the bowl cavity, make sure you trim off the excess straight portion(not the flared portion) that sticks up inside the bowl so it doesn't interfere with the float.
Are both checks in place and good?? The rubber check can look good but fail to work correctly, you should always replace it at any rebuild.
Old 06-23-2010, 05:00 PM
Some Punk Kid
Well it wasnt total rebuild..i did nothing with the bowl or accel pump..and it worked just before i cleaned up the main body
Old 06-23-2010, 07:10 PM
ericnova72's Avatar
More for Less Racer
If you use the wrong main body to metering block gasket it can cover the transfer hole also, as can the wrong metering block to bowl gasket.
Just follow the passage through the carb, it is a real simple to follow circuit from the bowl to the shooter.
Some carb cleaners will curl the edge of the umbrella check in the accelerator pump cavity and cause it to not work properly.
Old 06-23-2010, 07:30 PM
Some Punk Kid
yeah i guess i gotta triple check to see if the passage is clear again..bowl to block is good forsure..ill check again tho
no carb cleaner touched the accel pump
Thanks for the responses..everything is gonna be considered here for sure, gonna be something to make me slap myself
Quadrajet Carb??????? zbhover Engine 15 08-26-2010 08:57 AM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
Solex carb rebuild Kaefer'60 Engine 2 11-25-2004 05:53 AM
my first carb rebuild montea Engine 1 10-01-2004 07:49 PM
holley 600 carb rebuild TheViper Engine 2 09-16-2003 09:52 PM
