carb rebuild kit - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2003, 07:15 AM
Post carb rebuild kit
Where can I find a carb rebuild kit. FOMOCO
carb data plate info - C6DF B B 6AC.
2 barrel on a 69 302/auto trans/no ac? has a
gas leak on front of carb. not leaking around
the gasket but from where the likage moves the
lever on the front of carb(dont know what that is
called).
thanks
Old 01-20-2003, 07:37 AM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
Post
I had the same carb on my truck. NO ONE around here had a rebuild kit for it (but they could sell me a rebuilt carb.) so I said screw ya'll and bought a new 4 bbl carb from jegs. I would get a new carb unless your wanting to keep it original. then I would buy a new carb and put the old one in a box...edit..... I had to have found a kit for it cause I can remember changing the gasket your talking about. can't remember the name either..vaccum accelerater pump/diaphragm or something.. so check all the parts stores in your area, if memory serves, I found it at an old parts store in a tiny town. had dust alll over the box. probably been sitting there for 20+ years.
[ January 20, 2003: Message edited by: crazy larry ]</p>
Old 01-20-2003, 03:14 PM
aka Duke of URL
Arrow
[quote]...has a gas leak on front of carb. not leaking around the gasket but from where the likage moves the lever on the front of carb (dont know what that is called).<hr></blockquote>
That is called the accelerator pump and the diaphram is most likey ruptured.
The complete repair kit is FORD D4AZ 9A586-A (CT-499-D) and the accerator pump diaphram seperately is FORD C4AZ 9B559-A (CM-463).
If not still available from FORD, get back and will find another source.
Old 01-20-2003, 03:21 PM
New Member
Post
walker most likely has one, i worked at their plant hetre in town and they make thousands of kits. their claim was that the make kits for any carb there is. id check with them
Old 01-20-2003, 04:34 PM
Post
Autozone has the kits or can get them. I just rebuilt one a couple of months ago for a 66 289 and the kit covered up thru 70 302, I beleive. And yes, that is most likely the accelerator pump blown, and I would do the whole rebuild cause of the blow out could be inside, particuarlly if the car has set long enough to evaporate all the fuel from the carb bowl.
Trees
Old 01-20-2003, 05:11 PM
Post
Thanks I will check out ford and The car had been setting since july 02..They guy just decided to sell it after Christmas.
What is the contact info for walker?
thanks again..
Old 01-20-2003, 05:33 PM
New Member
Post
well i dunno for sure i can call the office here in the morning and get the number for you. the sales office for walker is either in las angeles or in st. louis
Old 01-23-2003, 01:20 PM
New Member
Post
i called ant talked to them, soory it took so long to get back(getting ready to get married) they said that only a distributor an buy directly from the, very well could have been hot air but the people i talked to wouldnt even give me the number. I should have expected it, thats the kind of thing why i no longer work there
