Carb Reccomendation Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2005, 09:31 PM
1985fiero's Avatar
1972 Nova Turbo Lsx
Ok I am looking to get the best carb that is user friendly (for the most part) that is going to work with my combo. thanks guys
chevy 355
220 dome forged trw pistons 11.87:1
215 cc dart iron heads 64cc combustion 2.05/160 valve
flat tappet solid cam specs are adv duration 290/298 .540/.558 lift
victor jr intake
car will be driven minimal on street weekend warrior will go on afew around town bouts maybe 50-75 miles a weekend give or take. just want to know what carb everyone has out of box luck with (i know there is no such thing as out of bunch bolt and go but something with little adj needed.
thanks for your help
dan
Old 09-28-2005, 10:38 PM
GoneNova/406's Avatar
sounds like you need to decide first if you want a 1/4 mile car or a strip car because they are different animals and require different carbs.
Old 09-29-2005, 02:03 AM
Drive it Like u Stole it!
isnt a "1/4mi car" the same as a "strip car"? i think you meant strip car vs track car - but in either case, i dont think they require much difference in carburetors. no matter what, it's still a street car, so any performance carb out there will work fine. when he starts putting out over 800 hp, or has forced induction of some sort, THEN start thinking about specialty carbs.
as for a recommendation, i'd say holley 750 dp or bg speeddemon 650 dp. if you've never driven a double pumper carb and want it to be a bit "easier" driving, go with a vacuum secondary.
Old 09-29-2005, 06:34 AM
Technical Support Barry Grant
Which Carburetor
On your combination we'd recommend using a 650 Mighty Demon carburetor.
Old 09-29-2005, 06:55 AM
well for the street i'd go with a 750 mighty demon or holley 4010 or 4011.for the strip i'd go with a 650,700 or 750 double pumper.big difference at the gas pump.holley also has the race 750 annular booster dual 30cc pumper # 9379 might be what you want.check jegs online.those are all in about the same price range and performance range or close anyway.
Holley 4777 carb. questions. TVR383 Engine 16 07-05-2009 02:23 PM
I'm going to make a bonfire out of my car blown69stang Engine 36 08-22-2005 03:36 PM
What is this crap in my carb? Jmark Engine 7 05-15-2005 07:08 PM
Edelbrock Carb Chadman Engine 17 12-09-2003 01:10 PM
priming a new edelbrock carb crshrmn3 Engine 8 10-29-2002 05:04 PM
