Carb recommendation for 400 s/b - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2002, 04:24 PM
New Member
Post Carb recommendation for 400 s/b
I am looking for recommendations for my 400 cu. inch Chevy small block. I am running a mild cam and have a 9 to 1 compression ratio. It currently has a stock Q-Jet in the 600 cfm range. It's ok but needs work and rather than jump into a rebuild I want to explore options. Besides IT'S SWAP MEET TIME!! Thanks for any and all help.
Old 09-25-2002, 04:35 PM
Steve karch's Avatar
Post
A 600 - 750 cfm carb would work fine. I like the Edelbrock for easy tuning but a Holley will work well also. What kind of intake are you using.
Steve
Old 09-25-2002, 04:56 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
I have to agree with Steve on size but, HOLLEY HOLLEY HOLLEY with vacuum secondarys. And chances are you don't need a "double pumper"
Old 09-25-2002, 06:14 PM
NAIRB's Avatar
Post
I would recommend 6 strom 97s with automatic fire extinguisher!
Old 09-26-2002, 04:37 PM
New Member
Post
Steve, I am running a late '70's low rise Edelbroch manifold. Nothing special but does well at idle through top end. Don't know how many HP it adds compared to newer offerings.
