Carb Recommendations? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-04-2007, 10:05 AM
stepside454's Avatar
Originally Posted by 71C10
BG's Road Demon would be better for 5500 RPM and below, unless your cam has 220 or more duration, as per their recommendation.
BG Link.
Yep Agreed
  #17 (permalink)
Old 02-04-2007, 12:53 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Last journal entry: 1999-2001: Getting it on the road
Wiki Edits: 16
Originally Posted by mattson70
VE, is that volumetric efficiency?
Yep. Its a representation of how much the cylinders actually fill compared to their volume. A 5500 rpm engine probably is around 85% VE.
A Qjet would be a great choice. They are rated at 750 or 800, but they have secondary air doors that only open as much as the engine needs. That's why the same basic carb was installed on everything from V6s up to the Caddy 500. They're a great way of making sure you have enough carb without getting too much.
  #18 (permalink)
Old 02-04-2007, 01:15 PM
71C10's Avatar
U.S. Army Retired
VE, is that volumetric efficiency? So, buying a 750 cfm carb to put on a motor that eats only 600 cfm at 100% VE is probably a waste of money? Thanks for the help.
Like Curtis said, look at the picture of the 388 dyno sheet. The column "Air 1 scfm" is the measured amount of air passing through the carb at each RPM step.
backfire thru carb airraptor Engine 11 06-12-2009 02:30 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 09:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-08-2003 11:22 PM
