-   -   Carb Recommendations? (http://www.hotrodders.com/forum/carb-recommendations-108257.html)
mattson70 02-03-2007 07:18 PM
I've got a 88 GMC Sierra with a decently built 383 stroker in it. It has 700 r automatic trans and is 2wd. It has a Edelbrock performer dual plane intake on it and I was thinking of going with a Edelbrock carb but I'm just not sure. Is 650 cfm enough or should I go to 750 and with what carb builder? Thanks.
jpelli 02-03-2007 07:27 PM
Ran a stroker in my Model A , after trying a few options I settled on a Holley street avenger 670 cfm, needed little adjustment , ran great. Joe
grandpaws 57 02-03-2007 07:29 PM
carb choice
I agree with carter/edelbrock choice.Smaller carbs [500cfm] will deliver better throttle responce.It all depends on what you are doing.Smaller is almost allways better.
71C10 02-03-2007 07:46 PM
Cam duration, compression, RPM at shift point, etc...
To give you an idea of what is possible, here is my old worn out 388 with tiny cam, good heads, 600 Edelbrock, Used 388 dyno session.
mattson70 02-03-2007 07:48 PM
So, smaller cfm will mean more torque and bigger cfm will give more HP? I'm looking for torque as it's a around town stoplight-to-stoplight cruiser. It's got a Holley 600cfm on it now but it's a 1997 model and I just think it might be time for an upgrade.
mattson70 02-03-2007 07:57 PM
Hey, thanks for the info everyone. That was an interesting dyno pull. Nice torque numbers.
I'll list what's been done to my 383, maybe this will help in carb selection.
It's a 72 Chevy high nickel block, scat stroker crank, 400 rods, Keith Black pistons. All rotating assemblies balanced. Block was line-bored, windage tray, high-volume low pressure oil pump. Cylinder heads were milled, bowl-cut, ported, polished and flowed. Stainless steel valves and Z28 valve springs. Chrome molly push rods with screw in studs, 1.6 roller rockers, comp cam and cam was degreed. Distributor has been curved to match the cam. Heads and intake match-ported. Edelbrock perfromer dual plane intake, 600cfm holley dual feed carb with 1 inch riser plate. After burner headers 700r 4 trans with B&M shift kit.
I've looked at Holley's website, Edelbrocks, and Barry Grants. All nice stuff, I just need to know what cfm carb to go with. Thanks.
DeathRattle 02-03-2007 08:03 PM
It also comes down to what RPM are you going to be hanging out at. Plan on being at or above 5500 a lot? Or mostly less?
mattson70 02-03-2007 08:05 PM
Mostly less than 5500 rpm. Looking for torque as opposed to high rpm HP.
71C10 02-03-2007 08:10 PM
Cam specs?
mattson70 02-03-2007 08:16 PM
I wish I knew. I bought the truck from the 2nd owner and he had a lot of info but not the cam specs.
curtis73 02-04-2007 12:12 AM
At 100% VE that 383 ingests 609 cfm at 5500
At 85% VE, it ingests 519.
600 would be more than enough.
mattson70 02-04-2007 05:49 AM
VE, is that volumetric efficiency? So, buying a 750 cfm carb to put on a motor that eats only 600 cfm at 100% VE is probably a waste of money? Thanks for the help.
stepside454 02-04-2007 08:25 AM
I think Id consider using the 625 Demon.
mattson70 02-04-2007 09:12 AM
There's a 650 cfm speed demon on Ebay for $419. Brand new, manual choke, comes with spring kit and lines. Is that a fair price?
71C10 02-04-2007 09:41 AM
BG's Road Demon would be better for 5500 RPM and below, unless your cam has 220 or more duration, as per their recommendation.
BG Link.
