Carb Recommendations? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2007, 08:18 PM
mattson70's Avatar
I've got a 88 GMC Sierra with a decently built 383 stroker in it. It has 700 r automatic trans and is 2wd. It has a Edelbrock performer dual plane intake on it and I was thinking of going with a Edelbrock carb but I'm just not sure. Is 650 cfm enough or should I go to 750 and with what carb builder? Thanks.
Old 02-03-2007, 08:27 PM
jpelli's Avatar
Ran a stroker in my Model A , after trying a few options I settled on a Holley street avenger 670 cfm, needed little adjustment , ran great. Joe
Old 02-03-2007, 08:29 PM
grandpaws 57's Avatar
"Don't need no V/8"-grandpaw
carb choice
I agree with carter/edelbrock choice.Smaller carbs [500cfm] will deliver better throttle responce.It all depends on what you are doing.Smaller is almost allways better.
Old 02-03-2007, 08:46 PM
71C10's Avatar
U.S. Army Retired
Cam duration, compression, RPM at shift point, etc...
To give you an idea of what is possible, here is my old worn out 388 with tiny cam, good heads, 600 Edelbrock, Used 388 dyno session.
Old 02-03-2007, 08:48 PM
mattson70's Avatar
So, smaller cfm will mean more torque and bigger cfm will give more HP? I'm looking for torque as it's a around town stoplight-to-stoplight cruiser. It's got a Holley 600cfm on it now but it's a 1997 model and I just think it might be time for an upgrade.
Old 02-03-2007, 08:57 PM
mattson70's Avatar
Hey, thanks for the info everyone. That was an interesting dyno pull. Nice torque numbers.
I'll list what's been done to my 383, maybe this will help in carb selection.
It's a 72 Chevy high nickel block, scat stroker crank, 400 rods, Keith Black pistons. All rotating assemblies balanced. Block was line-bored, windage tray, high-volume low pressure oil pump. Cylinder heads were milled, bowl-cut, ported, polished and flowed. Stainless steel valves and Z28 valve springs. Chrome molly push rods with screw in studs, 1.6 roller rockers, comp cam and cam was degreed. Distributor has been curved to match the cam. Heads and intake match-ported. Edelbrock perfromer dual plane intake, 600cfm holley dual feed carb with 1 inch riser plate. After burner headers 700r 4 trans with B&M shift kit.
I've looked at Holley's website, Edelbrocks, and Barry Grants. All nice stuff, I just need to know what cfm carb to go with. Thanks.
Old 02-03-2007, 09:03 PM
DeathRattle's Avatar
Some Punk Kid
It also comes down to what RPM are you going to be hanging out at. Plan on being at or above 5500 a lot? Or mostly less?
Old 02-03-2007, 09:05 PM
mattson70's Avatar
Mostly less than 5500 rpm. Looking for torque as opposed to high rpm HP.
Old 02-03-2007, 09:10 PM
71C10's Avatar
U.S. Army Retired
Cam specs?
Old 02-03-2007, 09:16 PM
mattson70's Avatar
I wish I knew. I bought the truck from the 2nd owner and he had a lot of info but not the cam specs.
Old 02-04-2007, 01:12 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
At 100% VE that 383 ingests 609 cfm at 5500
At 85% VE, it ingests 519.
600 would be more than enough.
Old 02-04-2007, 06:49 AM
mattson70's Avatar
VE, is that volumetric efficiency? So, buying a 750 cfm carb to put on a motor that eats only 600 cfm at 100% VE is probably a waste of money? Thanks for the help.
Old 02-04-2007, 09:25 AM
stepside454's Avatar
I think Id consider using the 625 Demon.
Old 02-04-2007, 10:12 AM
mattson70's Avatar
There's a 650 cfm speed demon on Ebay for $419. Brand new, manual choke, comes with spring kit and lines. Is that a fair price?
Old 02-04-2007, 10:41 AM
71C10's Avatar
U.S. Army Retired
BG's Road Demon would be better for 5500 RPM and below, unless your cam has 220 or more duration, as per their recommendation.
BG Link.
backfire thru carb airraptor Engine 11 06-12-2009 03:30 PM
700 R4 tv cable hook up at carb murrsue Transmission - Rearend 4 10-18-2006 10:50 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 04:25 PM
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 03:38 PM
Need some pointers on Holley carb crshrmn3 Engine 2 02-09-2003 12:22 AM
