carb related problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2008, 02:14 PM
Ive got a Mk1 vw golf clipper, only a 1800 8v weber 34/32 dmtl carb and lately been having problems, when driving it just wont rev over 3500 rpm unless i set the c/o worryingly high, the problem started when i disturbed the dizzy, if i set the ignition timing to how it should be 6degree retard with vacuum off it just wont go,
retarded 11 degrees with the mixture screw wound out (over rich) it revs thru 8000 rpm (red line) but with a massive power loss (only 115 bhp)
which leads me to think, is it advancing too fast? or is it lacking fuel up top end?
any help much appreciated
cheers Pete
edelbrock carb problems cool48 Engine 7 01-09-2010 08:35 AM
Lean problems with BG Speed Demon carb Sixtyninemercury Engine 29 04-16-2008 08:02 AM
carb problems iamsmitty General Rodding Tech 5 09-07-2004 02:52 PM
Holley Carb Problems.. Meangreen Engine 8 06-24-2003 08:00 AM
Q-Jet Carb Problems...engine dies. MopaRV Engine 8 01-31-2003 11:00 AM
