Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb risers
Thread: Carb risers
Old 08-27-2012, 07:38 AM
lance-burton lance-burton is offline
Carb risers
I have a 1930 Model A, the 4 cylinder engine has been modified by adding a mild cam, balanceing the rotating assy, lightling the flywheel, over size intake valves, electronic ignition and I am adding a Stromberg 97. Does a two inch riser do anything to help my engine or will it effect the preformance? Presently on a Dyno I have 60 hp at the rear wheel with 147 lbs. of torque at 3000 rpm, and a stock rear end.
