Carb secondary issues??????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 07:46 AM
New Member
I have a 350 SB that has a cylinder or two dropping out at low RPM. I start the truck and let it warm up. The engine revs fine at first start. When I take off the engine has a cylinder or two dropping out (I guess) when the engine is loaded up at low rpm. The engine (for lack of better terms) flutters and vibrates irregularly like a cylinder or two is dead. When the rpms get up a little the engine smooths out. This will continue when the engine is in a loaded low vacuum state. Once the rpms get up she smooths out. Then when the engine is at full operating temp (160 stat, lots of compresion) the fluttering/dead cylinder symptoms go away. Could this be a card secondary isssue? (Edelbrock 1405 vacuum secondary, new plugs and wires, timing ok, fuel is fresh............)
Old 03-28-2006, 08:56 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Seems like a lean flutter to me. Try changing the rod springs to a really soft at first. If it goes away you can keep getting heavier to you find the limit.
Holley carb has me at wit's end cool rockin daddy Engine 23 06-02-2005 02:38 PM
What Came first Chicken or the Egg, or Carb Adj vs Timing riesman20 Engine 19 07-18-2004 10:26 PM
rochester 4 jet carb, rich Walker Engine 2 07-13-2003 09:42 AM
Marine 383 carb issues drn Engine 5 07-06-2003 10:18 PM
Holley carb & powervalve info Frisco Engine 9 06-25-2003 01:47 AM
