Carb Selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-13-2009, 08:42 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Carb Selection
Okay, i have a 355 sbc with a performer rpm cam and intake. Its going in a 86 cutlass supreme approx 3500 lbs. Heads are #441 stock chevy, approx 9.5:1 compression. Converter is B&M 2200-2400 stall. Transmission is a TH350 and rear end gear is 3.42. I plan on taking the car to 6500-7000rpm when i visit the track. Now i went through my box of carbs and i have a few diferent choices. The three carbs are:
Holley
1850-4
0576
Holley
3918 or 3318 (Can't tell first two numbers were too close.)
2527
Carter AFB Competition Series
9605S 0384
they are all spread bore, and the two holleys i believe are 4160 series. The holley numbers came off the choke housing. Can anyone give me a suggestion on which one will work best, some info on them, and maybe some upgrades i can do like converting the 4160 to 4150. Thanks in advance
Shane
Old 05-17-2009, 08:30 PM
Rustydawg's Avatar
Cruzin w/Elvis in Bigfoots UFO
Any chance that this Holley 3918 / 3318 is a 3310? That's a pretty popular 750.
The Holleys offer a lot more adjustment and tuning potential compared to the AFB. Buy Holley's assortment of springs for the vacuum secondaries and read up on tuning them, you should be in good shape so long as they're mechanically sound.
Old 05-18-2009, 06:11 AM
Listen and Learn
Wiki Edits: 7
i am almost certain on the number, i will go and check today. is the 4150 conversion worth the fifty bucks?
Quadrajet Carb??????? zbhover Engine 15 08-26-2010 08:57 AM
Demon carb selection 383mudlust Engine 6 04-07-2007 02:03 PM
Carb selection... lumberjacknooj Engine 10 07-18-2005 04:23 PM
HELP cam, intake and carb selection? sniper4570 Engine 5 01-15-2002 08:16 PM
