Carb selection - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2012, 07:03 AM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
Carb selection
Howdy all,
I recently dropped a 355 in my 92 z71 and I think the Holley 450 is a little low on cfm. I've got a chance to get an edelbrock 750, mech secondaries cheep and freshly rebuilt.
My motors a 95, bored .030 over, speed pro hypereuectic(sp) 4vr flat tops, stock crank turned down .010, melling MTC-1 cam, new lifters, stock heads rebuilt off the 95, and a Holley Contender dual plane intake with a stock HEI. thoughts on upgrading to a 750?
Old 07-20-2012, 07:22 AM
Banned
Originally Posted by MrPhotographer06 View Post
Howdy all,
An edelbrock with mechanical secondaries? Really?
The 450 is a little low for peak power, but it sounds like you built a towing engine, so NBD. I'd just send the holley to a reputable shop and tell them you need it rebuilt and tuned, it may actually cost a little more, but the end result will be better on the street.
That being said I have two Edelbrock 1406's I'm running now and they work well and are idiot proof.
Old 07-20-2012, 07:29 AM
As you suspect, 450 is too small. 600-650 CFM is "perfect" for a 350 used for towing. Cam and intake will have a major effect on this. The MTC-1 is "good" to about 4,800 in a 355. Is "Contender' roughly equal to "Performer"? I must ask, as nobody I know uses Holley intakes. Edelbrock or "stock"...
Agreed, no Edelbrock carbs are "mechanical" secondary. They have an "air valve" in the secondary. While the butterflies ARE mechanically controlled, the air valve is vacuum controlled (just like AFB/AVS and similar to Q-Jet), and "meters" how much air/fuel passes through the secondary. The 750 is a little "big", but won't act like it due to the vacuum secondary.
Jim
Old 07-20-2012, 08:03 AM
Banned
Jim
Also, a 750 Edelbrock doesn't flow close to 750cfm... though neither does a holley...
If you rarely go over 3500 RPM you won't notice a difference with a cfm increase, but you will notice a difference with proper metering.
Old 07-20-2012, 05:30 PM
Army Strong
Awesome guys. Thanks. After I read my post just now I realized I said mech secondaries on the eddy, when my Holley I have now has mech. Lol
But thanks, I believe I'll go get it. I'm averaging 14.5 Mpg's on the truck with 33"x12.50 tires on it. Not bad. Maybe the 750 won't hurt it too bad.
Old 07-20-2012, 05:56 PM
E.T. divided by $ spent= Speed
450 is too small. A 600cfm vacuum secondary carb would be best for a mild 350.
A 750cfm vacuum secondary would be OK too,a bit big but should work with tuning.
Personally I get rid of all metering rod carbs(Qjet Eddy AFB) as I don't have the patience for that BS. To me a Holley is best as they are a cakewalk to tune.But thats up to preferance.
Old 07-20-2012, 07:53 PM
vinniekq2's Avatar
basic rule of thumb to pick carb size=cubes times 2.IE: 350 cubes will work well with 700 cfm,so a 650 will work great and so will a 750.Bigger carbs for dual plane intakes and someone thing a more sporty tune now or in the future. The 750 will not hurt fuel economy.
carb selection help sik87blazer Hotrodding Basics 1 06-01-2011 12:49 PM
carb selection david ahluwalia Engine 4 03-03-2009 05:33 AM
BG carb selection? rumpity_z28 Engine 18 02-04-2009 04:54 PM
Carb Selection 1974 gto Engine 17 01-10-2006 11:51 PM
carb selection savman1 Engine 6 06-23-2004 09:13 AM
