Carb selection on 383 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 11:05 AM
I have a 383 stroker should I use the 650 mighty demon or go with the edelbrock 750
Old 03-05-2012, 07:48 AM
Supporter of the 4.3 liter V6
All depends on what you like. I would suggest edelbrock, in my opinion they are simpler to work on. But you should look on both edelbrock and holleys website and read their descriptions and decide for yourself
Old 03-05-2012, 10:35 AM
carb selection
Go to Quick Fuel .com and look at the selection area. They will give you a math problem to do ....What RPM is the motor going to spin at max. then figure out the problem and choose the closed carb to the cfm they tell you...Example:
I am going to run the Lunati 60101LK cam with vortec heads...the cam spins max figures are 5500 rpm...Vortec's will allow about 300 more rpm's ...The cab they said to use was 590cfm~! So I am buying the Quick Fuel 600 cfm with vacuum secondaries....Better to use smaller than bigger...600, 650, max 670cfm for your build if in the 5,500rpm range..
Old 03-05-2012, 02:01 PM
Carb selection
Thanks for the info if any else has something to say it would be appreciated.
Thanks thumper 33
406 sbc carb selection PLEASE HELP!!!! 2fast4love Engine 30 03-12-2012 04:08 PM
496 stroker cam selection hotboy454 Engine 1 07-21-2011 05:14 PM
carb selection help sik87blazer Hotrodding Basics 1 06-01-2011 12:49 PM
Carb selection for 427 sbc MadmanMark Engine 8 12-20-2007 05:57 PM
Carb selection for 85 GMC 4.3L V6 tn-cat Engine 5 05-22-2006 08:40 PM
