Hi Guys,
My son never takes the easy road, he seems to prefer challenges!
Current case in point . . . he bought an 86 Chevy C-10. It
originally had a six cylinder in it and someone pulled it out and put
a V8 in it. It was supposed to be a 350 but according to the numbers
it's an 1978 305 with a 2bbl carb. (I was working a lot of overtime
when this occurred so I didn't have the opportunity to see/talk him
out of buying this "gem" before he bought it!)
It's always been a booger to start - especially when it's hot.
Poking around on it the other day we found the base of the carb is
evidently warped - if you spray carb cleaner at the base of the carb
the engine revs right up. The carb only has TWO bolts that hold it
down! And there's only two holes for bolts in the carb! Now, in
what automotive engineer's world was this ever OK??? (I'm a little
grumpy at automotive engineers right now . . . just changed the
battery in my Mom's Grand Prix -> who in their right mind thought
molding the windshield washer reservoir around the battery was a good
idea??? GRRR!). We took the carb off and cleaned everything up and
put a new gasket in but it's still got a good leak around the base of
the carb which I imagine is from it only being bolted down in two
places for the last 30 years - the carb base is probably warped.
It's also got this "hot air" choke thing that I haven't investigated
yet, but just looks like a bad idea! (I'm figuring that exhaust cross
over in the manifold is plugged up too)
Digging around I found a factory Chevy aluminum intake that should
work fine on this '78 engine - it's casting #14057053. (I figured if
we're going to muck about with repairing the carb we might as well go
to a Q-jet).
I was over at my mother's house the other day and while poking around
the garage looking for a set of refrigeration gauges I ran across two
quadrajets in the garage. I dunno the story on them, though I suspect one of them is mine from many years ago (my father has passed away so I can't ask him).
One of them is 7043526 which figures out to a 1973 Oldsmobile 350
carb. It has a hot air choke and the fuel inlet comes straight in
rather than coming in from the side. I have no idea on this one as I
can't every recall an Oldsmobile even on the place.
The other is a 7029202 which figures out to a 1969 Chevy 350 - I
suspect it came out of my 'vette as I remember replacing the QJ in it
with a Holley (it was a long time ago!). It's fuel inlet comes in from the side and it uses a divorced choke.
My first question is whether either of these 350 jetted carbs work OK
on the 305? Or should we change the jetting? If so, to what?
My first choice would be to rebuild and use the second carb but I doubt
my son keeps this gem of a truck for long and I really don't want to
let that carb go.
The first carb will require a fuel line to be fabricated but that's
easy enough to do. The aluminum intake we have does not support the
hot air choke but there's a retro-fit kit available to convert it over
to electric choke.
Also, both will obviously need rebuilt. It's been a while, but I've
rebuilt a couple in the past. Looking around I see that Autzone,
Oreilly, and NAPA all have kits that are pretty reasonable - around $15
to $20. Years ago I always got my kits from NAPA and was happy with
them . . . does anyone have any recent experience with carb kits and
which ones are better than others?
Thanks!
Steve
to a Q-jet).
let that carb go.
to electric choke.
Thanks!
Steve
