carb set up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2013, 11:30 PM
carb set up?
So every time I drive my car, I need to adjust the carb. Even after driving for a while, I need to mess with it again.
Idle comes up, then goes back down. Runs fine, then rough.
Fuel level seems to be set right, in the middle of the sight.
SBC, low compression, mild cam, Performer intake, Summit racing 600 cfm carb.
I replaced the feedback quad that was on there, wrong carb anyway.
I'm not a carb guru by any means. I've rebuilt a few quads and Holleys. Never had this problem before though.
Maybe another problem with the motor or something else?
Checked for a blown head gasket with the block checker thingy that goes on the radiator. No problems. I've adjusted, (re-adjusted, and re-adjusted some more) the lifters. All are set at 1/4 turn from "0" lash.
Old 06-15-2013, 04:23 AM
poncho62's Avatar
Wiki Edits: 5
Have you checked for vacuum leaks?
Old 06-15-2013, 07:30 AM
Proud LOSER
I had the same symptoms on my 750, idle would change and it did weird sht after driving it and it got warm. I lowered the floats below the sights, had to give the car a good hard nudge to see any fuel come out. That's all it took and it was cured after.
Old 06-15-2013, 07:32 AM
RWENUTS's Avatar
Possibly distributor weights sticking.
Old 06-17-2013, 12:20 AM
New dist. but checked the advance weights anyway. They're smooth.
Didn't have a chance to drive it, but adjusted the floats and ran it for a while. Messed with the timing again, Now I believe that I'm at 8 or so BTDC at idle and max of about 38 or so. Couldn't check what RPM, cause I was alone. With the bowls set lower, it seemed to run much better. Can't wait to drive it!
Thanks all!
Carb set up help. bygddy Engine 19 11-08-2012 07:37 AM
what carb for my set up dro21_polo Engine 5 08-07-2012 09:59 AM
How Do I Bulid A Two Carb Set Up buggmann Engine 7 08-03-2008 10:17 PM
3x2 carb set up popbreed Engine 3 09-12-2007 01:12 AM
What if I set up a carb on my rebuild... CamMan Engine 1 12-20-2003 07:55 PM
