Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb set up help.
  #30 (permalink)
Old 11-06-2012, 04:51 PM
bygddy bygddy is online now
Originally Posted by F-BIRD'88 View Post
Comp wants you to use something a little better for this camshaft.
They recomedn their medium size 986-16 spring.
I use a stock diameter high pressure single spring with similar seat and open specs.
This Summit racing Spring is similar to what I'm using
SUM-174000
Others are Lunati 73943
Isky 235D
Pioneer 810107-4
Pioneer Automotive 810107-4 - SummitRacing.com
You need to order 4 units to get 16 springs
They are packed as a 4 spring set pack.
Crower Performance Valve Springs 68304-16
Comp valve spring shim kit #4753 You need this to correctly shim the deep exhaust spring seats
to get the installed height right.
Should pick up the cam this weekend. And after I figure out heat for my garage I will likely pull the tranny, then get the heads off and go from there. Yes I will upgrade the springs then if you think its a must. Think maybe I will splurge on arp headbolts this time around lol....
