Carb Size - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-19-2008, 08:37 PM
406 bug's Avatar
9.82 @ 139mph
check the power valves. screw your idle mixture in all the way. if the motor keeps running, your pv diaphram is ruptured. All holleys (since 1992)have a provision that prevents pv blowout; however, since yours is older- this could be the prob.
  #17 (permalink)
Old 08-20-2008, 11:33 AM
Thanks for all you answers guys!!!!! I pulled the carb off gave it to my buddy he thinks the power valve is junk. H esaid if they backfire through the carb sometimes they will pop. He said there is a way to get rid of the power valve. By the way it is a holley850
  #18 (permalink)
Old 08-20-2008, 12:22 PM
Your local parts store sells an anti-backfire kit that protects the valve form being blasted apart. It cheaper than a new carb.
Bogie
  #19 (permalink)
Old 08-20-2008, 02:53 PM
kleen56's Avatar
My next door neighbor states he never runs his Holley's with the power valve. He said Summit sells them and they are called block off plugs and they go in place of the original power valve. I do know you have to rejet the carb to two jet sizes richer if your going to go that route.
http://store.summitracing.com/partde...5&autoview=sku
  #20 (permalink)
Old 08-20-2008, 04:29 PM
That's OK for a race engine, but running that kind of set up up on a street engine with richer mains will result in higher fuel consumption and emissions.
The valve in question, which today has become called the power valve because it's there to richen the mixture at WOT, used to be called an economizer valve as its presence allowed main metering to be leaned out which saved fuel during part throttle operation.
So yes you can run with out it if you richen up the mains, I rather doubt that 2 sizes up will provide sufficient coverage at WOT, one of the things engine designers do at WOT is to run the engine excessively rich, a bit beyond what's required for max power, for the purpose of providing some in cylinder cooling. The purpose of this is that it essentially makes the fuel act as if it were a higher octane, thus pushing the detonation limit up. If you run hard on the top end without this excess to the excess, you run the risk of buying some new pistons.
Bogie
Carb selection help SLR_65 Engine 2 09-03-2007 05:44 PM
what size carb John Jesnon Engine 7 02-10-2007 09:06 PM
what size carb cro77 Engine 7 02-08-2007 07:06 PM
what size carb do I have? henkelphoto Engine 3 02-13-2006 03:41 AM
Does this size carb. sound right shockers69 Engine 13 08-14-2005 11:49 AM
