carb size - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2010, 09:00 PM
1/8 mile monte carlo
carb size
i need to no what cfm carb. i should use i have a 427 big block 60 over 13.4 compression 663/680 solid roller cam single plane intake 2.19 intake 1.88 exaust. oval port heads with 256 intake runners.i only drag race this engine
Old 08-06-2010, 09:34 PM
27 t's Avatar
WHO WHAT ME WAIT I DON'T KNOW.
Last journal entry: Door skins removed
this might help...http://www.4secondsflat.com/Carb_CFM_Calculator.html
Old 08-07-2010, 12:50 AM
ericnova72's Avatar
More for Less Racer
850 would be minimum, but it is still a little too small, a 1000HP(Holley) would be better, or a 1050 Dominator but you would need a Dominator pattern intake.
Don't even bother with a Holley 950, it is a 750 main body with an 850 baseplate and doesn't flow anywhere near 950, it is badly misnamed.
holley carb jet size to elevation ratio mazdaRx7 driver Engine 2 03-16-2010 11:26 AM
Edelbrock Carb Size for Stock Buick 455 youngceez Engine 38 03-05-2010 10:54 AM
what size of carb should i use on my engine pward2010 Engine 1 01-29-2010 01:30 PM
Carb selection help SLR_65 Engine 2 09-03-2007 06:44 PM
what size carb cro77 Engine 7 02-08-2007 08:06 PM
