Just did some reading on this the other day. From what I have read not personally experienced and from what a couple of ole school draggracers have told me that the Holley 750 double pumper mechanical secondaries is the best for the strip, the edelbrock performer best on the street with better tip in and fuel milage, with the Holley vac secondaries and Q-jet coming in last. I have the edelbrock 600cfm on a street car gets 18 to 20mpg,on 93 oct, it just isn't great outta the hole but does run strong on the interstate. Brian
Thanks for the reply Brian, The 600 in mine is the electric choke version which I think is economy calibrated, I had the edelbrok 750 on it but it seamed to idle rich I wasnt familiar with the idle circut on them it appears that it is separate from the rest of the carb so maybe I didnt adjust it correctly I bought a vacuum guage maybe that will help.
When I adjust the mixture (engine at operating temp and timeing and idle set) I usuall start out with the mixture screws 1 1/2 to 2 turns from bottomed. then adjust them till I get the fastest smoothest idle. The vac gage should get you dialed in.Brian
The idle circuit consists of the metering rods and primary jets. After that the air bleed screws are the only adjustment. I have been running Edelbocks for years. I usually jet down until I get a lean stumble and then jet up one size. The Edelbock manual has all of the pertinent info on setting it up. You can go to their website and download it if you don't have one. Having a gas analyzer would make the job a lot easier. |
i PUT THE 750 EDELBROC on we took it to the strip and it ran .1 slower but the temp was 95 and it was humid it didnt seem to rich and ran fine we are going to take it to the night races for better air and see how it does. My dad brought up a point that I am not sure it is valid or not but he was thinking because we took the wheel wells out and are not running a hood scoop it may be sucking air from the carb at the track end maybe that will be the next thing to try....
The Edelbrock is a good all around simple bolt on and go replacement, but it is not that good of a performer. If you are looking for lower et's at a track you need to rethink your carburation.
Hi KGRIFF,
I was watching horse power tv one weekend & the young guy was running a Nova, & it was breaking up at the other end of the strip, there was an older drag racer there that said just what your dad said, "air is sucking fuel out of the carb"., & that he needed to put something in there to stop the turbulences, I don't remember what they did to straighten it out though. Take care, rich |
[/IMG]
| 283 stalling, carb size etc... | 59vette | Engine | 7 | 07-04-2007 03:29 PM |
| Having a hard time with cam choice | blacksunshine | Hotrodding Basics | 12 | 02-14-2007 11:21 AM |
| EFI to Carb conversion advice needed | 1953 Homer | Engine | 2 | 12-19-2006 11:16 AM |
| Response to cuda | IgnitionMan | Engine | 28 | 03-02-2006 07:32 AM |
| Headlight amps and fuse size? | JohnTN | Electrical | 6 | 07-13-2005 07:43 PM |
