carb sounds like jake brake - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2004, 10:00 PM
New Member
when I apply throttle to my motor it misses and pops back out of th carb so bad you have to close your ears.anyone know why its doing this. its not the timing, spark plugs wires, gas, feul pump, none of the usual things.
Old 04-21-2004, 10:13 PM
I would say its timing but you say its not so I assumed you checked it also could be some wires swapped up somewhere double check your firing order if all that checks out I would look to the distributor for bad cap or rotor. ITs been my experience that the things I dont think it could be usually is the culprit so doulble check everything dont just assume.
Old 04-21-2004, 10:20 PM
New Member
started just driving down the road. not the wires. havent checked the cap or rotor. you owuldnt beleive how loud this is. i thought it was knocking at first
Old 04-21-2004, 10:34 PM
Jmark's Avatar
May have burned an intake valve.
Old 04-21-2004, 10:45 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
You might have wiped an exhaust lobe on the cam, bent a pushrod severely, a rocker could have come loose, or a cracked/burned intake valve.
If this is a small block Chevy, it's not uncommon for a lobe to be wiped out.
You can run a compression test.
If all cylinders are fine (and no noises from the motor), you probably have a wiped lobe. If there's noise present, you probably have a rocker loose, bent pushrod etc.
You can check this by pulling a plug wire at a time and snapping the throttle. Once the popping stops (or mostly stops anyway), you've found the affected cylinder.
If one cylinder shows low or no compression, suspect a cracked/burned intake valve.
My money is on the lobe.
Old 04-21-2004, 11:51 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Thats my diagnosis too.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
Old 04-22-2004, 05:22 AM
Rubberman2003's Avatar
Mine did that for a bit, i stretched my timing chain. Also just make sure your TDC is still where it should be.
Old 04-22-2004, 06:31 AM
I'm with BestMech, but will put a quarter on a rocker seat busting out or a rocker roated to the side.. Pulling a plug wire trick will tell you which valve cover to remove for the obvious fix. If all the rockers are intact, then check the valve adjusments to pinpoint a bad cam lobe.
Trees
Old 04-22-2004, 06:18 PM
New Member
started it again today. popped a couple more times then ran fine. but now doesnt run on all cylinders
Old 04-22-2004, 08:17 PM
troy-curt's Avatar
You have already been told what to do. Pull the plug wires until you find the miss, then pull the valve cover, look at that cylinders rocker arms and push rods. Check for a broken spring. Can't get much plainer than that.
Troy
_______
