carb spacer
I have a Air Gap intake and a Holly Street avenger Carb on a Small block 400 in a 1968 camaro. My question is there enough room for me to put a 2" carb spacer with a 2" cowl induction hood. There must be someone out there that has tried this with all the camaro owners out there.
Good luck. |
Spacer......
On my Buick 231 engine,the gas in the carb would boil,living in the country,i didnt have a place to buy a spacer,(for temp control) so i made a 2 inch one out of a piece of OAK,it worked perfectly.
Duh I know it only that it it only four bolts to take the hood off, matter of fact the hod is already off. I was just wondering if there were going to be any clearance problems if I put a 2" carb spacer. I figure or I have be told that a 2" spacer is better than a 1" spacer.
I have a Speed Demon on an 2" spacer on an Airgap, but Iīm using a four inch cowl hood
as my four inch tall K/N filter has the K/N filter lid on it. If the hood was too close to the filter lid it would defeat itīs purpose. ![]() ![]() Slap your hood back on with the four bolts and do the clearance check with plasticine, putty.....whatever. |
2" worth the cost ??
in my bucket i don't have a clearance problem.... sorry i have no idea bout your camero... but was wondering... i have the same set-up, airgap and edelbrock 600.. does it make a diff if u use the spacer ?????
re DUH
If you need a 2 inch spacer then you have the wrong intake manifold,that top flow air filter rarely makes more power than a standard solid top filter.(I dyno tested my car with the filter you are using,you can have the top for free)The street avenger carb is not their best carb in the holley line up! |
| The Following User Says Thank You to cobalt327 For This Useful Post: | ||
PatM (09-28-2012) | ||
and you'll probably get a lot of posts now how wrong I am but thats just my opinion!Spacers on different designed intakes is a different story you can tune with spacer 4" 2" 1" 4 hole or open but those intakes are designed for full throttle blasts and not designed for street performance! Jester |
On cowl induction if the cowl scoop isn't sealed: the in rushing air into the engine compartment through the grill and the cooling fan and under the car can cause air pressure that over powers the cold air coming off your window in the cowl area into the scoop and actually be blowing hot engine compartment air out the scoop inlet the faster you go the worse the condition! now your cowl scoop is acting like a vent expelling hot air and not bringing in cool air! The other problem about cowl hoods that are not sealed to the intake is they act like para shoots at speed! once the air pressure under the hood is greater then the pressure entering the scoop and over powers the scoop openings ability to exhaust this extra pressure your front end begins to lift !!!! They look cool and ones going on my wife Comaro LOL But sealed Jester: By the way really nice Camaro Last edited by painted jester; 09-27-2012 at 03:21 PM. |
carb spacer
I have a Victor Jr on my 1967 Camaro and I can not use a spacer with a Cowl hood. I even have to use a drop base 3" air filter. BTW my spacer is a 4 hole 1" spacer.
| I need a carb spacer | Ekki | Hotrodding Basics | 7 | 04-13-2012 08:09 PM |
| Best carb spacer style Edelbrock carb | truckboy61 | Engine | 2 | 07-24-2011 09:18 AM |
| Will adding a 1 inch carb spacer affect carb tune? | eric32 | Engine | 29 | 02-09-2010 12:13 AM |
| Carb install, spacer or no spacer? | MM in NM | Engine | 3 | 03-17-2006 06:23 PM |
| carb spacer | sah | Engine | 14 | 08-26-2004 07:39 AM |
