An open type spacer will normally help the top end. A 4 hole type the bottom. A spacer can help with mix matched parts. A carb that is too small mounted on a low intake will build volosity high enough to bounce the fuel off the plentum floor causing fuel seperation. An open spacer will help. A carb that is too big has a reduced signal. A 4-holl type tends to help in this case. Almost always, a stock low type intake will like the added height of a spacer. As stated above, try one and see. They're cheap. You may not gain anything, and in fact may loose a little. Then again, it might be what the dotor ordered. While testing spacers, remember that jetting changes will be needed to optimise them. Dan
