Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Carb Spacer or Not?
Old 08-28-2005, 02:57 AM
IanRiordan IanRiordan is offline
If a spacer helps, then your carb or manifold is too small for your package, if it hurts too big. use a spacer as a tuning device. generaly if a four hole helps more than an open one the carb is too small and vice versa. Remember, comp, stroke, rod length etc play a major role in controlling air speed. Just use spacers to dial in your car, then make appropriate changes.... unless your class won't allow them.
